1 - 2 of 2 Posts
Hi all, i have my car lowered on eibach 15mm springs and got camber bolts fitted. I went in today to my local garage which uses hunter system to get FRSU done by TDI north settings. As in the settings it states 1mm front wheel toe out which is 0.5mm each wheel, the system was all in degrees. Am i correct thinking that 0.5mm toe out is -0.02 degrees?
Other question is, what shims do i need to get my rear wheels to 0.75 negative camber and 1mm rear toe in?
Thanks!
1 - 2 of 2 Posts
