Strange one this i cannot describe it
basically at low speeds i can here what can only be described as a groaning noise it seems to be coming from the back end (maybe its there all the time but not able to hear it) sometimes its there sometimes its not
when i press the brake pedal the noise disappears release it appears
cars just had a FRSu and springs fitted up at grinspeed with a shim inserted
Help??
Ive had worn out wheel bearings both front and rear on my FN2. Both times they have produced a kind of alternating humming sound is the best way I can describe it. Not really noticeable at slow speeds, and when in going in a straight line. And it increases in volume the faster you go and gets loud when you take a turn.
So perhaps your issue is brake related rather than wheel bearings...?
If it only started making the sound after the rears hubs where taken off to add shims, Id start looking there if I was you.
/ntn-front-wheel-bearing-honda-civic-type-r-fn2-07-11
100% the wheel bearings-Tegiwa sell good and cheap ones
no one service coudn`t tell me which is the problems so i bought them to one of my friends reccomandation, i was very determined to fiind the problem, and with big budget as well , luckily were the bearing so just £70 per pair
+ 3 hour service to replace it
NTN FRONT WHEEL BEARING HONDA CIVIC TYPE R FN2 07-11 | Tegiwa Imports
don`t waste the time, just do it , it tooks me 6 month to find the solution
