1 - 17 of 17 Posts
I have an FN2 with black team dynamics 1.2 wheels. However, the current black wheel nuts are past their best and need replacing. Any recommendations?
Steve
Cheers, forgot about Cox
Nice cheap fix.
They keep all the odd ones from customers who want security nuts fitted and then package them up for us.
Just noticed that the ones currently on the car are not Honda ones!
OEM Honda wheel nuts are radius fit for the Honda alloys, most aftermarket wheels are taper fit.
If your wheel nuts are taper fit you can buy any M12 x 1.5 taper fit wheel nuts for the car, just be careful of the length of the studs on the hub as some nuts are not deep enough to fit.
mine are aftermarket (team dynamics 1.2) so i need tapered ones but which?
Sent from my SM-G955F using Tapatalk
Yes - you absolutely need to know what seats your alloy wheels have - Honda are ball/radius seat and aftermarket almost always taper/60 deg.
Do not use the wrong seat type nut - that road leads to disaster :eek:
Tegiwa have a good selection, just ignore the OEM Honda ones, the others are taper fit (all are 60 degrees) and good quality, these can be used on OEM wheels but require a adapter washer.
Forget about Tegiwa - I’ll take a look
There are some 45 degree ones about - often used in racing applications ;)
I'm using steel nuts from Rare Rims ebay store and McGard security nuts. Want to upgrade to Rays steel nuts for jdm points, buy they are pricey.
I use Muteki open ended black wheel nuts on my ATR.
Makes EVERY wheel nut a security nut. o_O
Discussion Starter #16
I was looking at the Muteki ones on Tegiwa earlier
1 - 17 of 17 Posts
