1 - 14 of 14 Posts
Ex-Pat Geordie!
Sooo! decided to go out tonight and rotate the Rear wheels with the front ones as they've been on some time. Then took off to the garage to do tyre pressures. Immediately the Tyre Deflation warning light came on. So just continued and set the front up with 35psi and the rear with 33psi. Re-set Tyre Deflation system and off I went. Went over to supermarket to get a couple of things and the Tyre Deflation came back on? re-set and off I went and again it came on. Re-set it again then went in and cancelled it. Do you have to drive a set mileage once you reset it?
I also noticed that there wasn't much meat left on both the front and rear pads so they'll be getting changed very soon, is there no wear indicator where they squeal once you get so far down as at almost £56 for fronts, I'd imagine there should be so as to avoid metal on metal.
On our 8 gen we had a very slow puncture to one tyre-6psi approx over a couple of months. The tyre deflation warning would then trigger. After topping up the tyre and resetting that would be the end of it till a couple of months later.....
With a new (pair) of tyres, the above tyre now gone, the warning has never so far returned. With the correct pressures to each of the 4 tyres the rolling circumference of each you would assume similar to each other.
Ex-Pat Geordie!
I don't think I had Tyre Deflation warning on the 8G I had, that was a 2007 2.2 ES.. I'll set it again in the morning on my commute to work and see how it fairs on a longer journey..
My '06 ES did'nt have either. Ours is the facelift ('59 plate). Maybe the 9 gen system is more sensitive.
Nturb..
My tyre monitor tyre a wobbler a while back.
I was sure I had a slow puncture but everytime I checked the pressures they were ok.
I reset mine but it came on again so I turned it off for a while and deactivated it again a few days after.
It’s been fine since.
No idea why it did it as I hadn’t had the wheels off.
Ex-Pat Geordie!
Re-set it this morning on my commute to work and Tyre Deflation didn't come back on so must be sorted now. Another thing I have noticed though is that the factory fitted Michelin that were on the back are bloody noisy compared to the two Good Year I moved to the back.
Ex-Pat Geordie!
Well, went out to do the rear brakes in the peeing rain this morning, jacked car up, took wheels off and went to loosen the rear calipers. To my surprise they've changed it from bolts to an Allen bolt? It's also the only size I don't have otherwise a special tool required. Has anyone done the rear brakes on the facelift 9G and if so, what size Allen key is required or is a special tool needed. I don't have a comprehensive Allen set and I don't want to buy one either.
Cheers for any help.
Neil.
Ex-Pat Geordie!
Forget the above. Was in the shower as I was like a drooned rat and remembered it's a brake key you need, after all that remember I bought one hen I had the 8G.. DOH!
Ex-Pat Geordie!
Did the brakes this afternoon with no probs, my Lazer wind back tool was totally hopeless for the Job so ended up going down to Halfords to get on of those little cube multi windback fittings so did the job great, even got a couple of quid off it with the trade card.
It didn't all end well though. I'd left the locking wheel nut key on the locking nut and by the time I'd came back from my test drive and noticed it had fallen off somewhere. Ordered a replacement from Cox for £19 that included VAT and Shipping so no big deal. Hope I don't get a puncture in between no and the replacement arriving [smilie=sadtard.gif]
i-Vtec
It will be a 7mm allen key, but you probably know that now, lol. I left my locking nut on mine a couple of months back, but luckily enough id only driven up to the lock up to drop off the trolley jack and found it at the kerb.
Ex-Pat Geordie!
Discussion Starter #12
I've got an allen key set but not the size needed to undo the sliders. I was well peeved when I realised I already had the tool as I bought that for my old 8G... The NS piston took a wee while and a bit of effort to wind back but got there in the end, the wee cube with various options on it from Halfords is a great wee tool, nice and compact. Pads I took off had about 1 - 2 mm left so changed them just in time before metal to metal and then it would have been discs too.
Pads I fitted were Blue Print, had the recommended by a couple of people. No way I'm buying OEM at almost £60. I've fitted Eicher in the past but the dust that comes off them is unreal.
Ex-Pat Geordie!
Discussion Starter #14
I went into ECP today for some grease for the sliders. Online it was £6.79 and with the discount it came to £3.99 and when I got there the on the shelf price was £2.99 so be careful with their sales. I tend to do OEM for engine servicing but for brakes etc, will go with the next best.
1 - 14 of 14 Posts
