hi all.i was thinking about adding wheel spacers to my 2011 1.8cts with 17"alloys.has anybody done this and what is the maximum size spacer i can use with standard nuts,or what size nuts i will need if i use a wider spacer?
Hi all. I was thinking about adding wheel spacers to my 2011 1.8 CTS with 17" alloys. Has anybody done this and what is the maximum size spacer I can use with standard nuts, or what size nuts will I need if I use a wider spacer?
I have 15mm Eibach spacers all round on my 5-door (also 17" wheels), which are no problem at all ...
The CTS starts with +10mm compared to a 5-door, but looking at mine, the equivalent of 25mm difference at the rear would be just fine ...
You can't really fit spacers of any size, using the existing bolts ...
Eibach spacers come with matching longer bolts ('splined' through the hub) - so, the existing nuts are always used ...
