1 - 9 of 9 Posts
I have an error on screen 'PGM-FI fault' so I need to read the codes but it's dark outside and I can't seem to find the ODB port!
Can someone kindly tell me where it is on a Right Hand Drive mk9?
Thanks.
Yes l can confirm what Halt said. It’s directly above the clutch pedal/rest, around where your left knee would be. So put your hand under where plastic panel ends and you’ll feel it right there or as Halt also said you’ll see it in the footwell with a torch if you look up towards the top left it’s staring you in the face. (kneeling outside car, head in footwell, look up top left)
Cheers, found it?
Plugged my eml327 Bluetooth box in and connected via Torque lite and I can read ecu data. Unfortunately when I try and view fault codes it says there are none on ecu0.
I have the PGMI-FI error on dash. So there should be codes.
Any ideas on what I am doing wrong?
Just tried a few other apps like:
Torque (lite)
Clear and Go
ODB Arny
MotorData
None showing any codes!
So is it that I need a better reader than my ELM327?
Reading the thread sounds like it could be the MAP sensor! On the 1.6d any ideas where it is as it's only about £20 so might be worth just fitting. Mind you if I can't reset the fault codes then I am no further on really.
So any ideas or just bite the bullet and take it to Honda?
it can come on and not register fault then clear
but if its staying on then there should be a code registered
you could try disconnecting battery for a while
1 - 9 of 9 Posts
