Motul RBF600 fluid is on its way
Cosworth streetmasters are on their way.
HEL brake lines are going to be ordered imminently... which just leaves one thing....brake discs!
Do I purchase a new set of OEM, or will i see any benefit for going aftermarket bearing in mind the price difference with some!
There seems to be loads on the market, to name a few....
Tarox Sport Japan- £250 for front discs and 180 for rears. All in over 400 quid for discs!
Tarox G88-Same as above
Tarox F2000- Same as above
DBA slotted 4000 series- Listed on ebay and with a quick conversion from australian dollars comes in around £228 quid.
EBC discs ranging from 140 quid for plain to around 200 for turbo grooved. Rears 45-90.
Stoptech powerslots- Around 200 for fronts and 160 for rears.
Brembo ep3 fronts ranging from 60-80 quid. Are these any better than OEM? Do Brembo do a drilled/slotted version? seen some on ebay but think they may be fakes?
EBC Plains/Brembo Plains/OEM plains- Any difference between them?
Compared to OEM discs from cox honda parts. All in, come to under £200. So is it really worth the extra expense, or are the main benefits to be seen via the cossie pads/lines and fluid.
