So I wanted to change my transmission fluid in my FN2 from the Honda fluid to Amsoil which is highly recommended on here. However, when I tried to purchase from Opieoils is seems they no longer import it from the USA into the UK but instead they recommend Redline MTL. Has anyone got any experience of this transmission fluid and in particular does it help with slightly notchy gear changes? I've linked the Redline fluid mentioned. Is this the correct one? Any help / advice is appreciated.
http://www.opieoils.co.uk/p-1019-re...al-transmission-lubricant-mtl-75w-80-gl4.aspx
Cheers.
Th eamsoil was ace. I'd see if you can get it from another vendor.
It fixed my notchy gear change a treat in the fn2.
Saying that opie know what they are talking about and wouldn't recommend inferior products
regrets his username
I used redline a few times, was awesome in the colder weather but a tad notchy in the warmer mths, I use to use Hondas spring/summer & swap over to redline when the temps plummeted
