Will these 6.5" components fit in a type S GT?
I've tried to get quotes from 3 installers, 2 have said theyd do it no problem, the 3rd a rarther experienced chap said NO, and if i did, id be wasting money cos they wouldnt sound right.
I checked out the Wiki but still couldnt be absolutely sure. I dont want to shoe horn the speakers in, cos theyre rarther expensive, so preferred a good fit and with adequate clearance after for a good SQ. Could some tell me definitively?
CS 265 Profi Vanadium - 2-way 17cm components
Mounting depth without / with ring:66 / 64mm (6.5" speaker )
37mm voice coil
CS 265 Vanadium
6.5 inch
Part number 231532
Peak power handling 180 Watt
Nominal power handling 120 Watt
Minimum amplifier power 75 Watt
Input sensitivity 90 dB 1W/1m
Frequency response 39 - 35.000 Hz
Impedance 4 Ohm
Crossover slope 2 x 18 dB/Oct.
Crossover frequency 2.400 Hz
Thermal protection HALO + PTC
Woofer W 165 Vanadium
Mounting depth without / with ring 66 / 64 mm
External diameter without / with ring 167 / 190 mm
External diameter with edges -
Installation diameter 145 mm
Fastening diameter 156 mm
Midrange -
Mounting depth without / with ring -
External diameter without / with ring -
Installation diameter -
Fastening diameter -
Tweeter CAL 26 Titan VOF
Mounting depth 20 mm
External diameter 51 mm
Installation diameter 44 mm
