1 - 20 of 75 Posts
Hi
Quick question should the window clear water from it's surface when it is lowered into the door? At the moment there is still water on it when I lower it then raise it.
It's on a 54 plate type R.
Martin.
As your Type R is a 54 plate I guess we shouldn't get involed - isn't there a forum more suited to the older Civic?
Of course we should get involved, we are still here to help and advise anyone that asks a question and not just fob them off to the relevent forum imh and yes there are other forums suited to older models
To the op, i cant answer that for you but i'm sure someone will be along to answer for you;)
#MrGrumpy
Everyone without a 2008 Milano Red Civic can just get out.
In seriousness, the 8G has the same problem - the trick is to either apply pressure from the inside as it winds down, or just wipe it before you get in.
Lol:D
The water is just normal rain water on the outside of the window, it has never cleared the rain off when it is lowered for as long as I can remember, someone here in work mentioned that it didn't sound normal that, so just thought I would ask if this is a normal civic thing or should I get it looked at some sort of seal has gone.
What's that got to do with water on a window?:spam:
Daft question but is it raining when yu try to clear the water?
#MrGrumpy
#MrGrumpy
Mine has never done it either - granted your model is older but I remember there being a thread about it on the 8G too so I guess it's a Civic thing!
#MrGrumpy
Bit of a wide range there mate, don't you mean "2008 Milano Red 2.2 Type S Civic"
I don't want to be too exclusive - otherwise what happens when I need help with something? :p:rofl:
Hi
Are the rubber sills on the windows starting to go green ?
They may need replacing ...
I hope water is not going inside your doors mate
#MrGrumpy
1 - 20 of 75 Posts
