Window washers seem to have stopped working today, might be the fuse but my headlight washers still work. confused. as they work both at the same time together then i'm wondering. do they have seperate fuses? or work off the same one? looking in the book the fuse diagram only shows the headlight washer and not the window one?
Discussion Starter #2
also, i know the fuse box is under the steering wheel somewhere but cant really see out to pull down?
There are two fuse boxes on the Civic, one is located where you mention, the other one is in the engine bay, on mine (petrol version) in a black plastic box right under the hood top left.
Also check that the hoses have not blown off due to blockage or freezing up. Listen for the pump or water running out from the bottom of the wheel arch.
I'LL NEVER WALK ALONE
i've had trouble with my windscreen washers, i stopped the leak under the wheel arch by pushing the black hose firmly onto the bottle, bit it's still not right.........:(
how do i get at the hose attached to jets under the black plastic shroud ??
any advice appreciated !!
