Has anyone else had this problem, fill the windscreen washer bottle full and watch as one third of it drains away under the car from the front wheel arch??
I can't make my mind up what it is, but when the bottle is full to the brim it just starts to go down and disaapear?? I think I may have a hole somewhere but the bottle is in the wheel arch so is impossible (for a non techy) to get to.
I only ask as before I take it to be looked at I was wondering if anyone else had come across this problem. I haven't measured the volume yet to trickle out but will get a measuring cylinder under in the next couple of days to see what the tank is losing.
Just for measurement value what does the washer bottle hold (Litres)??
The leak is from where the neck fits to the bottle, there is an 'o' ring to seal the joint but it doesn't work, you only loose an egg cup full. Apart from sealing the joint with silicone theres little you can do.
