1 - 9 of 9 Posts
Had my car in the garage yesterday to fit a load of service parts and have an MOT and last night I noticed the washers were empty.
Parked up to put fluid in and it just leaks out underneath the drivers side bumper instantly ! So they've done something, what a bunch of incompetent ***** !
As they're shut today I might need to look at it myself, any ideas what/where to check ?
SHOCKD
Check all the pipes are connected properly You should be able to see the bottom of the tank from under the wheel arch on the drivers side (going from my 2.2)..
I had an issue where when I was pulling the stalk to use my washers it was squirting all over the engine bay and onto the floor. Turns out one of the pipes at the top was loose.
But if you are filling it and its coming straight out they may have punctured the tank itself or disconnected the pipe
1 - 9 of 9 Posts
