Dan
Just tried to use the windscreen washer, but for some reason it isn't working, I can't hear the motor working at all, there is waster in the bottle and the pipes are connected up to the washer jets. Does this mean my motor or pump is goosed:(. Is there anything I can try before I take it into the garage on monday.
I had a problem with mines there was no water coming out the hose joins just before the front cowling I seperated them and gave the one going to the tank a good blow not had a problem since might help might not
Dan
would this cause no noise coming from the motor at all or would I still be able to hear the motor but no water coming from the jets?
I think you should still be able to hear the motor have you checked the fuses ?
