Hi guys,
Anyone had trouble with their wipers?
When my wipers are set to auto, they work fine for a while. Then they decide to keep going, even if the rain has stopped.
When i turn them off completly, they still wipe the window another 5 or 6 times, then stop in the middle of the glass, rather than going back to the start position. i end up flicking the wipers on and off to try to get them back to the start position.
any ideas? motor packed in?
Hi,I had the same problem with mine,now I promise this worked for me,I waggled the stick up and down very fast for about 6 seconds about 4 or 5 times and I haven't had the problem since,mine now work fine,just take sensible care,hope it helps.
i have this problem and think i fixed it..when turning the engine off set them to off and after a few days when u shift it to auto they will work..?
Motor either needs replaced (£270ish fitted from Honda, or, if you're mechanically capable, taken out and cleaned. There's a how to on the forum somewhere..
Edit: noticed you're from NI, it's £271 from Donnelly.
