hi im installing some drls in the engine bay and planning to run a power cable for an amp just wondering if anyone knew of a grommet that i can use or would i need to drill a new hole for it ? i have a 2.2 cdti 2007
thanks in advance
:confused:
Dr. Evil
I'm sure there's already an opening you can use with a grommet in it. There certainly was on my Accord, but I can't say for certain on the Civic.
#MrGrumpy
There are two, one in each footwell. I used the one in the driver side for access through to the engine bay for my gauges.
Could you post s pic up of where? Be really helpful. I always struggle to find the access to the engine bay from the cabin?
just be careful if going through same place as the loom , i broke 2 wires in my loom when i did it
there is a trader on here that sells an auto on/off which mines you dont need to go through the bulk head, think it works of the battery when the volts drops etc
