tbgint ook zo stillekes aan door te dringen
over Keans:
'Moet je van ver komen?
Anders zou ik aanraden om eens tot hier te komen zodanig we alles eens kunnen bespreken wat al de opties zijn.
mvg'
To be continued, wie weet weet ik zaterdag dus meer.
I believe the ST suspension comes at around 900€. A KW set would be >1000€.
Off course they will see it...adjustable rings, yellow springs,...:laugh2:
It is allowed as long as there is enough ground clearance and all the necessary papers are there.
You can set the height as you want. When you need to go to the MOT you set it at legal height and there is no problem, it's that simple.
Interesting note in the describtion:
TUV approval and GOCA papers are available on request. 0
Somehow these adjustable coilovers would be an exeption on the rule that height adjustable suspension is not allowed?
Very confusing all this.
edit:
strangely, unfortunatelly not compatible with my 1.0L :frown2:
Wich is strange, I dont believe that the suspension components are different between our cars? or are they?
I also wonder, does the 1.5L have bigger brake discs than the 1.0L?
what would lowering springs only be? I've read around 400 dollars?
But If I'm not mistaken, when installing lowering spring you gotta have a camber kit as well right? And thats aroun 300 dollars?
A coilover set is complete and you dont need anything else? (+you can adjust the height manually)
Are you sure adjustable coilovers are allowed? I've read that it has to be a fixed system.
I quote:
'indien de vering in hoogte regelbaar is, moet deze veer op correcte wijze geborgd zijn, zodanig dat geen andere afstelling van de ophanging mogelijk is dan deze waarbij de bodemvrijheid van de niet-elastisch vervormbare onderdelen tenminste 11cm bedraagt'
So maybe a coilover system is not forbidden as such, as long as you fix the height of your height adjustable system
All well if they dont inspect your components, but if they do, you're basically ****ed.
Saturday I will meet with Keans, and I am curious to hear what he has to say about what I just told you.
edit:
It's not an exception, coilovers are allowed when all papers are available. I've had coilovers before and had no problem. But not all brands deliver papers with them, those are not legal for the MOT.
Can't say if there is a difference between the 1.0 and 1.5.
if you wish, you can delete irrelevant posts, we both know now what we need to know
belgians and their lowering issues
Related Threads
2006+ Honda Civic Forum
2.5M posts
103.9K members
Since 2006
