Hex Key sizes
1 reading
4.3K views 15 replies 8 participants last post by  Robbie
#1 ·
Morning. Can anyone tell me the hex key sizes needed to remove the front and rear shock and drop links please. Thanks
#4 ·
They worked for me, just used the handle of the double ended screwdriver from the car's toolkit to hold it.
the shock top nuts are pretty well protected from corrosion anyway so should loosen easily enough.
most likely you will need a cutting disc to get the drop links off anyway.
#16 ·
When I changed my front drop links, the old ones had a hex that you could get a spanner on allowing you to stop the ball spinning. Why aren't all ball joints make like this as its so much easier to get the damn things off. Took 30 minutes to do both fronts including getting all the tools out and jacking the car up.
Did the fronts on my MX5 last week and they had the recess for an Allen key. Mmmm, 3 blinking hours they took me, as the double wishbone suspension made it real awkward to even get the dremel in with a cutting disc.
