How to use tap into the fuse box (Option Connector)
165K views 262 replies 47 participants last post by  pitt66
#1 · (Edited)
How to tap into the fuse box (Option Connector)
Many people have asked (and will ask) how to hard wire a TomTom, Snooper, extra power sockets, LEDs etc into the fuse box and there are lots of methods around the site if you search, But this one is my favoritet and was posted by 'Stef' a few years back and is well hidden, So I thought I'd revive it :)
You will need:
  • Fuse (Size dependant on what you are connecting (20A Max)
Locate the Option Connector in the top left of you under-dash fuse panel (It should be empty and not have this blue connector).
Use the spade connector to connect the +ive power cable of your device to the relevant pin. Then find a ground point nearby for your devices -ive
Connect to bottom left pin for +12 with Ignition on or top right for +12 when side/head lights are on.
Insert your fuse into position 27 to activate the option port and you are done.
See Stef's pic below.
(Ignore arrows A & B, the are for something else)
Just a quick how to as I thought this would be useful :)
#2 ·
Great find!!
Thanks for reviving it :)
Would this make it easier to install RickHondaR's footwell lights?
#3 ·
There are a couple of other pins in there, anyone know if any are 12v constant? Will have to get the multimeter out otherwise...
#5 · (Edited)
But you could also short things out doing that.
Okay so just tested:
Bottom left is +12V constant
Bottom right is +12V switched with ignition
Top right is +12V switched with headlights
Not sure if top left is a ground or not yet.
Is their an option connector plug you can get from honda?
Using the bottom right is a nice way to wire up DRL for those whos cars are under warranty but do not want to cut the wires, just a straight plug in and remove.
#4 · (Edited by Moderator)
There are 6 pins in the connector, 4 across the top and two at the bottom. I have used a naming convention as you look at the pins in the open connector space.
Top far left: +12V when reverse gear is engaged, 0V otherwise.
Top left: A fluctuating voltage which ranges +0.3 < V < +0.8 when ignition is switched, 0V otherwise. No idea what this is for.
Top right: +1.3V with sidelights, 0V otherwise. Again, not sure what this is for.
Top far right: +12V with sidelights, 0V otherwise.
Bottom left: +12V constant from battery.
Bottom right: +12V switched with ignition, 0V otherwise.
To find a ground source, there are bolts that hold the pull levers for fuel cap and bonnet behind the plastic trim which you can route a wire to easily enough.
#9 ·
Little bit of an update; one of the two feeds, either the +12V constant or the +12V ignition, are disabled when engaging reverse gear.
Very peculiar!
#10 ·
So before I go poking around on the other pins in the option connector, does anyone know what they do? Would like to find one that doesn't switch off when engaging reverse :confused: so will have the multimeter out again over the next few days.
Can't find anything in the official documentation.
#11 ·
Guys I would like to make a final statement on this following testing.
#49 · (Edited)
Just to confirm this also applies to the option connector in the (9g's), but it seems the pin for fluctuating voltage +0.3 < V < +0.8 has been deleted.
9G Fuse Panel
BTW The lower drivers side dash panel simply and easily unclips (no screws) giving good access to fuse box/MCIU #1
The option connector is rotated 90 degrees on the 9G and all pins live without fuse 27 (Something different on new models)
#13 ·
No, both remain on.
I had assumed the top far left to be a ground connection but as it was +12V when in reverse this caused my connected devices to switch off - as it wasn't a ground anymore!
Just had confused myself slightly so I went and did some more testing and got the above results.
#15 ·
I had no trouble with the mini spade connectors mentioned in the first post - they fit the pins exactly and have a nice simple crimp connection onto the wires.
Not sure what you have available though?
Even if you locate the plug I wouldn't count on it coming with the correct pins for wire connection...
#19 ·
True but you can't see it unless you get under the dash... agree with less chance of a short but as long as you pull the fuse in #27 before fiddling about then you're safe.
Each to their own but can't personally see the advantage in trying to source the connector TBH!
#21 ·
+1, they aren't going to short when connected. Just need to make sure that you've removed power when connecting the spades in case of accidental cross contact but then again it's a fused supply so shouldn't suffer as the fuse should go first...
#22 · (Edited)
So, am i correct in saying that u MUST have a fuse in #27?
Wat if i were to connect multiple items (gauges) to the ignition +12v, considering each gauge has its own fuse? Would i just multiple each fuse for the gauges together and then put a slightly bigger fuse in #27?
Would that work?
Also, with the +12 with side lights on, assuming side lights are parkers/headlights. Can that be used to power the lights for the gauges?
And again, a fusing concern here?
#23 ·
Would that work?
You need a fuse in #27.
Not sure what gauges you're using but mine daisy chained together so I didn't need to route them all back to the connector.
If you're using gauges with inline fuses you can use something much bigger to activate the connector.
Remember that if you connect them in series the current is the same across the circuit so your inline fuses will need to be able to cope, so I'd suggest connecting them in parallel with something slightly larger than the sum of them in #27.
#24 ·
My plan was to connect one wire to the option connector, then connect that wire to a fused junction/distribution block and then connect each gauge off that.
I am using Autometer gauges, 5 of them, just for fun :)
My other concern is for the lighting of the gauges. How would the fuse in #27 work with that?
#25 ·
That will work as each of the branches will have a lower value based on the resistance of each gauge and the fuse in #27 will total that.
Not sure I understand your last question; the lighting would also be fused through #27 as long as you wire everything through the option connector.
#27 ·
You'll never need that much - despite having 5A fuses I bet those gauges draw way less current than that. I have 2 Prosport gauges with a 10A fuse, that powers the gauges, lights and electrical sensors and I think 10A is too high!
Will check the tech specs when I can get in front of a computer.
#29 ·
This guy has done some testing - 6 gauges and less than 1A draw!
How Much Current Do My Auto Meter Gauges Draw? - YouTube
So, I guess after watching that little demonstration, I would get away with a 10Amp fuse in #27 and even that would be over kill.
Thank you so much for your help. It will make installation so much easier now knowing the option connector pins.
BTW, with reference to side lights, am I correct in assuming that this means parkers/headlights?
#30 ·
You are very welcome.
By sidelights I am referring to the first light setting on the stalk, before your headlights - you might know them as position lights? As soon as you have any form of headlight switched on then that connection is +12V.
#31 ·
Gold!!!
Currently in the process of making my gauge pod and also going to attempt to move the centre screen/clock display from the middle of the dash to the right of the speedo. Big work ahead for me at the moment.
Once its all done, I'll post some pictures up for all to see.
#32 ·
Good luck!
FYI the piece to the right of the speedo is non-removable; it's part of the moulded dash so be really sure before you go to remove it :)
Look forward to the pics.
#35 ·
1.3V is really low though, even for LEDs I'd expect a minimum of 5V? I didn't test what the reading was with the interior lights on/off which was a bit of an oversight now I think of it :facepalm:
#39 ·
well what can 1.3v power?
LEDs?
Nope, they need about 3.3v
HFT
bluetooth may work with 1.3v but i doubt it.
Lets not forget the other one that has .3v and goes to .8v.
What can that power?, nothing.
That's about where I'm at! :hmmmm2::hmmmm2:
