OIL - 2012 UK Honda Civic excessive oil consumption problem
Oil
149K views 246 replies 70 participants last post by  ChesterLong
#1 · (Edited)
Hello All,
Hope somebody can please help me.
My UK 2012 Civic 1800 petrol is using ca 1 litre of oil every 500 miles. It has done less than 40K miles. I bought it secondhand from Honda and it has always been serviced by Honda and has been very well maintained. I reported it under the warranty but the dealership just said it was normal, and it's got worse over time.
Honda are saying to fix the oil problem it will require a new head gasket and 4 pistons/ring kits and that will take 16-hours labour. And until they start the job they wont know what else is needed and if it will be successful.
Can anybody help? Heard anything similar?
#213 ·
2012 civic here with with crazy oil consumption. I used lique molly engine flush before I changed oil, but it did nothing. I have looked in the cylinder with an inspection camera and the top of the pistons
are covered in thick carbon. The threads on the sparkpluggs have oil on them, but that oil is fresh. Would to much blow by thru the pistonrings really cause oil on the threads?
Has anyone tried an pistonsoak? I have ordered some b12 chemtool and are gona do an soak.
#218 ·
Your motor (probably, maybe) is affected if the serial number of the motor is below R18Z4-1030320. You can find the number somewhere on or around the engine.
The only way to be sure is to remove a spark plug and film the inside with an endoscopic camera. If there's R3A stamped on the top of the pistons, it's bad. If it's R1A, it's good.
At least some of the Civics MY2013 are affected because I own one from 06/2013 and we're having problems.
#225 ·
I don't know if ya'll know but at least on the german Honda website you can check your VIN (after creating an account) and it will say in what year your Civic was manufactured. And although mine was registered in 06/2013, it says it was built in 2012.
So it actually may be that only 2012 models are affected but some of them were registered in 2013.
Cheers.
#229 ·
I'm a bit late to the party. My 2012 Civic has been eating a bit more oil that it should since the beginning (bought it at 70k km), but I was not paying enough attention to that (first car). Now at 130k km, it takes roughly 1l for each 2000km. So the oil cans started piling up in the trunk and I can't be overlooking the problem anymore (haha). Any experience how bad can it get? It does not seem to make sense to me to invest into a repair of such an old car.
Anyway, I wanted to thank everybody for sharing information here, it's been very helpful!
#237 ·
Another 9th gen 2012 Civic owner. Bought this car on August last year for 7.000€ and 212.000 kms (Spain). I've tried everything but nothing worked. My engine is between those affected engines. I was really excited when I bought the Civic because it was the car of my dreams but when I discovered the excessive oil consumption on this forum the nightmare just became.
I thought about keeping the car and topping up with oil every now and then but my car also have a check engine light. That light is the PD0420 code, which means "Catalytic converter system, bank 1 - efficiency below threshold".
Catalyst System Efficiency below Threshold
As I've read on other forums, I wonder the catalytic converter is affected by the lost oil. That made me always be worried because I couldn't keep a car which might be damaged at any point. It's such a pity because the car works great, but it already has +220.000 km and it would'nt be a good idea.
I think I'm selling it next week to a dealer, even if I'll lose a good amount of money.
The good thing is that I found an Accord VII 2004 2.0, 160.000 km, in an excellent condition. What a great and reliable car! It's funny how I needed to go back to a well built car in order to maintain my mental peace.
In short: if you own a 2012 Honda Civic, you should get rid of it as soon as you can.
#244 ·
Another Civic owner here. Bought a 1.8 model from 2012 with 95.000 km in the begining of the year. I paid 11.000€ (in Portugal cars are very expensive) It has been consuming around 1L per 1000km. I dont know what to do. I dont like having to add oil every month but I dont want to scam a person and selling the car saying everything its okay. I could sell it an assume the problem but that way I would lose a lot of money and I would rather lose that money on fixing the problem.
Changing the pistons and everything that needs to be changed will solve the problem forever or the problem will eventually return?
Every other part of the car is impeccable. Is it worth fixing?
#246 ·
Bought a 2012 civic for €6500, 112k km and burns about 200-250ml 5w30 per 1000km over last 5000 km.
If I was first or second owner and got this after few years I would be furious, but at this price and consumption levels I think it's simpler and cheaper to keep topping up oil than new pistons (€800 + labor). Total replacement cost is 400k km of oil. I live in northern europe as well so the body will die from rust before the engine.
2014+ models are already €2000 more expensive so it's almost like it is priced in. And newer 10th gen civics have oil dilution + wet timing belt problems.
As mentioned previously in this thread, in the manual it says that up to 1L/1000km is okay and no warranty. Let's hope this line wasn't written only by lawyers and that they got input from engineers who worked on the catalytic converter and spark plugs 😂😂😂
#247 ·
That’s better than my 2012 I’m burning twice that plus I’m using 10w40. I’m 50/50 on getting an engine swap for a later model used engine but it is going to run me £1k just for an engine without labour costs. Still looking for a garage to quote for piston and rings. Now do I just cut my loses and trade it in or fix it this is the dilemma we all face.
