I have some strange electrical fault with my FK1 which causes the battery to drain. I have tried disconnecting the negative from the battery and connecting between the battery and the cable with a multimeter and measuring the current that the car draws when everything is switched off and the doors are closed and then it is 0.477A.
Trying to remove fuse #17 under the hood for "interior light" and then it suddenly draws 0.117 A
Trying to remove fuse #16 for "Back up" under the hood and then it suddenly draws 0.025 A which should be reasonable for stand by (?).
I've tried and disconnected the navi/radio power cables but it stills draws 0.477 A so it shouldn't be related to the Navi.
Any ideas what the problem might be?
Cheers,
Cheers,
