Ok, this is a bit of an anoying one.
I've had some problem in the last few days with the climate control not cooling the car as it should be, the compressor is not kicking in at all when the air is set to it's coldest.
The system is fully gassed with no leaks (had this done yesterday) but the compressor just will not start up... but here's the annoying bit.... the problem seems to be intermitent
First happened about 3 weeks ago when picking up a friend, the climate control just suddenly stopped blowing cold air (it was a warm muggy evening so it really noticed). Driving home later that night the compressor kicked in fine and started working again. Fast forward to Thursday just gone and again the compressor stopped allowing the interior to mist up really quickly (warm rainy night... cue having to pull over very quickly). Started working again later that night as I left the cinema to drive home, stopped working again 5minutes from home.
Had the system re-gassed yesterday it was slightly low but according the the aircon guy the level was no lower than he would have expected on a car with 62k on the clock.
Currently the compressor wont kick in but when it was kicking in the air was super cold, so it does seem to be doing it's job.
Checked both fuses and they are fine but can't check the clutch relay (I cant even get the thing out of it's slot in the fuse box, any trick to that?).
Anyone had similar or have any clues what to check before I call my local service center (they are good at the work they do but have no time it seems to talk to customers about symtoms, they just seem to want to take your keys and then give you a bill after)
