Sorry for resurrecting the thread
but I didn't want to create new one as I have similar question which hasn't been actually fully answered here.
I wanted to check coolant level in my Tourer and I'm not able to see if there is anything in the coolant resevoir tank.
The radiator is properly full and the coolant is blue-ish (should be original Honda coolant as the car's new).
When I took off the cap from the tank then there is a black rubber hose attached which is wet with coolant (let's say up to 10 cm / 4 inches).
So as the rubber hose is wet up to those 10 cm does it mean that coolant level is ok?
Or does it mean that it's actually too low (so the hose is wet but nothing can be seen in the tank itself) and I need to fill it with coolant?
