Hi all, I recently had a rattle coming from the front of my 54k 07 1.8 Type-S which i got fixed under warranty by the dealer (40 days since i bought it now). The problem was a gearbox bearing.. Anyway after getting that done i've noticed another rattle that only occurs whilst moving when turning, it seems to do it both ways. It's not really loud on the outside with the window down but it's obvious inside with the AC/radio off. As far as i can tell it only happens when the car is under acceleration too. I've read a lot of horror stories about CV joints and what happens when they go bad so should i be thinking they need checking urgently?
I really can't be bothered taking it into Arnold Clark again (20 days warranty left) unless i really have to as they are 15 miles or so away and i can't really afford to lose the car for a period of time.
I've had a rummage under the car, had a look around the sub-frame area and found a loose bolt which turns easily. It is close to the right wheel and is keeping the plastic mud guard(?) thing on underneath. In fact the bolt felt rusty and the plastic around it moves quite easily but doesn't feel like it would fall off or anything. After fiddling a bit and having just washed my car, the noise seems to be gone but i still get the occasional slight rattle so just not 100% what it is, I would of thought CV joint problems would carry on regardless?
I've inspected the CV joint from what I can see without taking the wheel off and I can't see any rips or tears in the boot, nothing obvious anyway... I am no mechanic so if anyone reckons it's the CV i'll happily take it to AC and get it sorted but hoping that its just this bolt possibly? Ugh, any ideas would be great.
Oh and just to edit, it passed it's MOT just a month ago!
