Does engine braking damage the clutch ?
9.9K views 37 replies 21 participants last post by  lucian18
#1 ·
Guys
just wanted to know does engine braking damage the clutch ?
i hardly ever use the brakes and it got me wondering if i am damaging the clutch, i would rather replace a set of pads and discs than fit a new clutch.
im talking about sensible gear changes here, no slipping it into 2nd at 50mph etc
cheers
#3 · (Edited)
^^ agree ^^
clutch wear happens when the clutch peddle is pressed and released - when the plates start to bind - fully engaged or fully disengaged = no wear
#6 ·
Engine braking is when the clutch pedal is not pressed and the car is in gear. If during this process a gear change is required then I suppose some wear of the clutch may happen while pressing and releasing the clutch pedal - but I expect this to be way way less than the wear on the clutch when accelerating and changing gear.
#7 ·
Would it? When accelerating up the and you disengage, the clutch would surely have less RPMs to match than when decelerating and changing down. Depends on torque however.
Note that clutch slip happens on a fully engaged clutch when accelerating mind you, so I guess that means the most "stress" is actually not at the point of gear change.
#13 ·
The injectors turn off when engine braking and you are advised to do it anyway as you have more control of the car whether you are using the brakes or not. The amount of torque being transferred through the clutch during engine braking is very small so the wear will be negligible.
#16 ·
My instructor reckoned it was ok to keep one hand on the gear lever and one on the wheel while driving around town, I failed my test that time! I'm not sure if all instructors always know everything
#19 ·
Continually using engine braking to slow down to a stop(or near stop)by going down each gear in sequence from 4th, will cause extra wear and tear on the gearbox and clutch, simply because you are regularly doing more gear changes than is strictly necessary. Whether it causes a premature failure however, is almost impossible to say for certain.
Engine braking is best used to hold a vehicle at a lower speed when descending hills, but to constantly use it as a substitute for brakes is really not a smart way to drive.
Some people routinely drive like this as if they are on a race track, and if thats what they want to do then its entirely up to them.
If i want to slow down i use my brakes, then select the appropriate gear for my speed before getting back on the throttle.
Dont make the mistake of thinking i drive slowly everywhere, because i dont. ;)
It is possible to make progress and be gentle on your car at the same time.
#23 ·
I used to use gears to slow down as my first car, a 97 clio rt :) had rubbish brakes so I used the gears to compensate. I did it in my c2 vts and had no clutch issues but have since changed my driving style as the logic of changing pads as they are cheaper rather than a new clutch seems more sensible and it is meant to be the way in new cars. My mum changes down through every gear but when just cruising I skip gears up and down...e.g 1st, 2nd, 4th, 6th from standstill then say 6th to 3rd if approaching a roundabout so in the right gear if there is a gap or if not straight to 1st or 2nd depending.
When having a sprightly drive, never skip gears up or down and while if I dont need to brake going into a corner I will rev match to a lower gear I cant do toe and heel braking so just brake and change down without rev matching which i know is not as good as rev matching but i am not Senna .....I assume what I am doing is all standard/ good practice stuff?
Regards
Whisky
#24 ·
It's not the engine braking that causes the wear, it's the changing down gears that does. If you really must downshift for this reason, rev matching will ensure you do as little wear as possible to the clutch. I try and rev match to reduce the amount of work the clutch is having to do.
#25 ·
Agree...now need to learn how to toe and heel so I can brake and Rev match :)
Question though, when I change down I slowly let the clutch in. There is no slipping as I am decelerating but feel if it's better for the engine and clutch to gently match the revs of the lower gear as opposed to a fast/ abrupt change like when you accelerate. Is this advisable?
Whisky
#26 ·
Yes that's correct. Harshly letting the clutch out while downshifting can cause instability at the front end. In some cases, a lock up. Smoothness is key. ;)
#27 ·
On a downwards slope the engine braking effect in the CTR is so great that you can actually hold 30mph in 4th gear and not have to use the brakes to slow down at all.
#32 ·
My wife passed her test after I did, and she was taught to shift down through each gear - which I find incredibly frustrating to observe!
I don't really recall getting much guidance on it but I was in a position where I could drive before I'd ever had a formal lesson so I probably ignored whatever I was told :lol:
#34 ·
I will often skip out gears when driving eg go from 4th to 6th or 6th to 3rd. or engine brake when going down hill in 4th and only brake when needed. but then I rev match all the time anyway. even if I am not having a spirited drive I still rev match on downshifts as it is force of habit.
If you can teach yourself to heal toe then great it does put less strain on your transmission.
#38 ·
It is acceptable at a practical driving test to go down each gear,it's a fault but it is considered not worthy of mention as long as the candidate reduces their speed before each gear change.Having said that the examiner will point out in the debriefing that is advisable to skip all the unnecesary gears ie if your coming up to a set of traffic lights and your in 4th gear then you should brake in that gear until just before the engine starts to labour and then you should press the clutch wait for the speed to reduce fruther and then select 1th gear to move off again.
