I have read your posts.
The behavior of your Tourer is different from my car.
I have a regular regeneration, every 450/600 km depending on the type of journey. The range only gets longer if I go over 150 km/h on the motorway. Regeneration lasts 12/13 minutes.
I have 260,000km
Your 12g PM in the DPF is starting to get a little high and no signs of a regeneration, you might want to check your DPF pressure sensor and pipes for blockage.
FYI
1/ At less than 7g the DPF system will automatically clean itself whilst driving once the DPF is up to correct operating temperature.
2/ At 7-11g the system will attempt to clean itself whilst driving regardless of DPF temperature.
3/ At 11-15g the system will alert the driver by blinking the DPF warning light on the dashboard. The owner should then follow the driving instruction explained in the owner’s manual to help clean the system. What is it? This requires a constant speed of at least 37mph to be maintained for up to 15 minutes. The best thing you can do is go for a 20-mile motorway run. Majority of the times this cures the warning. D) Above 16g the system will shut down to prevent damage due to a blockage occurring and the warning light will then be permanently illuminated.(Picture A) .If the owners continues driving with this light on permanently then the message may change to the exclamation mark symbol.(Picture B) .At this time you will need to go to the Honda dealer for them to hook up the HDS system to check whether you has a system fault or blocked . If they find the system above 16g then carry out a
I own a MT Civic 1.6 diesel 2013 model.
I followed your instuctions about script because I mistaken thought that it is mandatory for the use of PIDs..
My goal with Torque is to know when regen of DPF starts so I wont stop regen procedure before it is completed.
Anyway I am not a programmer but I try to go a bit deeper than simple user
I read from this forum and I am thankful to people like you that share knowledge.
i haven't written any instructions that in any word mentioned scripting.
My suggestion (as i wrote here already) if you want to use Torque (all forther described actions need to be done in Torque, not in Android or car settings!):
1. import PIDs,
2. configure icon in dashboard for active regen,
3. add alarm for active regen PID.
In that case you can hear alarm as soon as regen starts, and you can always check how it goes taking Torque to foreground.
Sure Torque must work in background always, making it possible to check PID states.
More ore less followed tips and here is the oucome
Before
During regen
Finishing regen
I am very thakful to forum and you personaly for sharing essential knowledge that HONDA had the responsibility to share but neglected to!
Coming to this is there any sensor or comercial add on besides obd + Torque that can added to cars control panel and show when regen starts in order driver not to stop car until it completed?
Aditionally I have noticed some markers that change a lot during regen:
1.DPF Calc Flow went 200m3/h from 40 m3/h
2.DPF Diff Pressure lowered from 1psi to 0,0 psi
3. EGT from 650 to 140 celcius.
Are these markers or any other markers distivtive so we can cearch in market for ex pressure DPF instument and use t next to oil pressure in cars control panel?
Sorry if I ask thing known for People or you here in this forum but I believe that a lot of people could be benefited through that.
