Views on type R calipers fiited to standard diesel calipers
9.8K views 28 replies 12 participants last post by  tristanmortimer
#1 ·
I know a few people on here have swapped their 280mm discs and calipers over to type R callipers and 320mm discs (typeR)
I would like to know if the braking is improved and if so by how much. Is there a wow factor? On my car I have upgraded the hoses to goodrideg S/S 6 line, have green stuff pads on front and rear, ebc gd discs on rear and normal OEM discs on front.
Quiet frankly I think the brakes are rubbish. I am wondering what all the fuss is over changing the hoses??
Any feedback most welcome.
Cheers Griffian
#25 ·
It wasn't just snake oil. The bigger disc diameter increases stopping torque even if the force applied is the same. Also you can use pad compounds that are not available for the derv set up. In my opinion it is a good cost effective upgrade for a standard derv which is fitted with barely capable brakes from the factory.
Sent from my SM-N9005 using Tapatalk
#23 ·
I've put the diesel caliper piston back in now I was only seeing if I could use the seals and piston as a temp while my new set came, but there all different completely unfortunately,
The EP3 piston was 54mm diameter and 56mm in length
The diesel piston was near 55mm diameter and I didn't measure the length but it was roughly 20mm longer
Sent from my GT-I9505 using Tapatalk
#20 ·
Diesel pistons are smaller.
I did a lot of brake comparisons in the past for upgrading my Derv to either FN2, Brembo or Stoptech 300mm touring kit, as I had a sample of all of them.
Can't find the stats I wrote down now but the FN2's have much larger pistons. Shame I've lost them meant to post them up ages ago. :facepalm:
#16 ·
Even still the larger discs + larger pads = more connected surface area = greater stopping power
If they werent much better, then why would honda spend lots of money developing slightly bigger ones??
#13 ·
Thanks FAHAD for your input. I have purchased the type r accord calipers and just need to sand blast paint and then get a repair sal kit for them. The carrier is the same as a civic type r carrier should will fit the hub.
Does anyone know the piston size of the type r civic piston compared to the stndard diesel caliper piston?
#12 ·
Do it mate, in my honest opinion its well worth it!
And Im only running standard CTR pads & discs, If you were to get some drilled and/or grooved and some EBC or Ferodo pads then would be even better!
The s/s lines are also well worth it, no sponginess and a progressive feel to the the peddle.
#11 ·
Ah, I never realised that the CTR calipers were single piston..
Coste is right though, although I can't find the link anymore, I distinctly remember back in the days when we were running THAOC, one of the Irish lads fitted CTR calipers to his 7th gen Accord... so there's a strong chance those twin piston calipers from the ATR will fit - just make sure you get the carriers with them mate!
#5 ·
Twin pots would be good considering the sticky caliper issues.
If they fit over the FN2 disk and use the same mounting points.
Hoses is the differnce between the brakes suddenly vanishing after 5-10 mins of abuse or 30 minutes of abuse ;)
Othe rthan that they just give you more accurate brake pedal control.
#3 ·
Not sure on the Civic but on the Accord I went from standard single piston front calipers over a 300mm disc to twin piston Accord Type R (Nissin) calipers over the same 300mm disc... and the difference is staggering!
I can only imagine how good it is moving from a 280mm disc with presumably single piston to 320mm? and possibly twin piston.
