121 - 140 of 154 Posts
The outlet from the valve is routed to a small stub near the valve, with a dark grey woven material covered tube pushed on.
Cannot identify that. I'll try look again on my next day off.
I couldn't recommend replacing parts without performing what is a simple diagnosis (especially when your problem could also be fuel injectors). But you wouldn't be the first...
Easy to diagnose if you can find the pipe. Totally agree with you about random replacement of parts, but the cost of diagnostics for an issue which confuses Honda themselves, I'm not sure it's not going to cost me more for a "pot luck" diagnosis and replacement parts from Honda rather than changing problem bits myself.
Can someone confirm if the following is the correct part for my 2006 car? I'm 90% sure it is but would feel better if someone could confirm or deny.
Search amazon for "F00R001166" and it's sold and dispatched by Amazon. I can't post links yet unfortunately.
Hi to everyone, first sorry for my English, and wanna thanks to this forum, and all of you guys who are writing helpful information and advices. .I have honda civic year 2008 , 2.2cdti, 125k mileage, and I had the same problem, the car doesn't start when the engine is hot, no any other problems, once i start the engine the car is ok.. I went in Honda Hendon (London ), they done the diagnostic and suggest to change the fuel filter, after the change they told me, that there are no errors on the diagnostic , but the car won't start again when hot. they suggested me to change the fuel rail, for price around ÂŁ1200,... i found this forum, and red about the fuel pressure relief valve, i asked the service advisor from honda, if they can check if the valve is ok, he told me that they can't, but if I buy the valve they will fit it with no extra cost, so i bought the valve from
Andy Hewing 07703903751- Ipswich
Email:andyhewing@gmail.com (the same adress from 1st page) the price was around ÂŁ122. they sent it to me, i bring it to honda and the guys from honda
fit it yesterday.. I took my car today and it's ok ..start better when cold and no problem when hot..thanks again to all of you guys. .the following photos are on the valve which I bought, the same part number like was described here, thanks a lot. special thanks to "DELTA PAPA" and "JON_G"
Valve Check
Hi all sorry to be dragging up an old post.
I'm looking for help. My car recently started struggling to start. It could start OK one morning and the next it wouldn't.
After getting the car started with easy start [I've been told this isn't ideal] it was good for around 5 days then it began struggling again, then it stopped starting again after a 1 hour drive [hot start up]
The engine seems to tick over fine it is just the starting up, once the engine is running it is perfect no loss of power or jumping.
The first garage advised to change the glow plugs and the oil filter which were done, i'm still having the same issues he has now said it looks like the fuel injector pump isn't producing enough pressure and said i could be looking at paying more than what the car is worth.
After doing some reading up I came across this thread and tested the pressure relief valve. I had a full pipe of diesel and around 15-25 ml of liquid in my bottle. After trying to source this part from a local place they wanted to see the car and the mechanic squeezed the priming bulb and he said it sounds like the bulb is drawing in air and that it should stay solid.
The bulb did go hard but around 10 seconds later it was squidgy again. He recommended removing the priming bulb and bypass this. After trying this and putting some easy start in the car fired up and it has been great again for the past 3 days, until today it has started struggling again.
Any suggestions as to why when the priming bulb was removed it started working fine again ?
Sorry for the long post and any help would be greatly appreciated.
So you correctly diagnosed that the rail over-pressure valve was leaking fuel but then instead of replacing it you let someone fiddle about with the hand bulb? Why?
If you are sure that the rail valve is passing fuel (as described early in this thread) then it definitely needs replacing! Replacement valves are widely available... I bought mine from a Bosch Service Centre but much cheaper ones (non-Bosch) are sold on eBay. Can't vouch for non-Bosch ones though.
Jon thanks for the reply.
I asked if he could source the part as I had no success locally EK brakes and Europart are both local but no joy. I google searched the part and found some but when the page had a part to fill the car details it says the part isn't compatible.
I should of mentioned my car is a Honda FR-V but i believe it is the same 2.2 engine as the civic and the accord.
My reasoning for taking it to the garage was to see if he could source the pressure release valve and he proceeded to look at the car.
Lots of Bosch Service Centres around... give your local one a call?
Yes, same engine (same problems!) but the part numbers can be different.
Good luck!
Hello,
I have hope you can help me out with my problem, I have a Honda CRV from 2010 with a 2.2 DTEC Diesel Engine, I have the following problem, always when I´m on the highway and want to acelerate from 100km/h to 130Km/k my car gets on limp home mode, when I read the code always the same one P0087, also when I reach 120 or 130Km/h the engine start to vibrate surd off, I do not have any issues by starting the engine at any time, what could be my cars problem?
Hello,
P0087 is low pressure in the fuel rail. My first thought would be to change the fuel filter (and do fit the proper Honda filter)
I have a problem in the car's ECU and it only starts when the car is cold, it throws error P0602 ... I have changed the ECU but the same thing still happens.
The solution is to change the fuel pressure sensor?
This thread is about the fuel rail over-pressure valve causing starting problems, and at the beginning does explain how to test if that valve needs replacement. I guess that you could have an ECU fault AND a leaking valve, so maybe you should follow the instructions to prove whether a leaking valve is responsible for your warm starting problems.
Neither the rail valve nor the rail pressure sensor could cause your P0602. Have you tried the forum search for more information on P0602? There have been a few reported issues of this although, as you say, it does appear to be caused by a faulty ECU. Are you sure the replacement was working properly before you bought it?
Hi there gents new to the site, I have a Honda civic I ctdi 2.2 2006. I absolutely love my car, but in the last 2 weeks I've had a nightmare with trying to start the car. The car turns over butt doesn't actually fire up, whether it's cold or hot. If I use easy start, it starts straight away, or even if I bump the car, she runs great. I've had a local garage replace a fuel filter, butt still woudnt start. So they put a diagnostic on it although there's no management lights on, and they said it was a Crank sensor. That's been replaced, and still won't start. I've tested the glow plugs and there all fine. I've even replaced another fuel filter costing ÂŁ53 from Honda. Was hoping this was the problem as I originally didn't have a Honda filter on the car. Its cost me 320 so far with my local garage to replace fuel filter and crankshaft sensor. Spoke to Honda Swansea and they said they would do a diagnostic at a price for ÂŁ109. I seem to be throwing money away as this may be a simple fix. Looking at the other posts, could this possibly the preasure value? Any help appreciated
It does sound exactly like it could be another victim of a leaking rail over-pressure valve, so I suggest that you follow the instructions at the beginning of the thread... the testing is pretty straightforward and you'll get a definite answer!
Whatever the outcome, please do report back.
Hi Jon taken the braided hose off and put into a container, turned the engine over for 10 15 seconds. Returned to the engine bay to find the container with fuel in. I'm going to order the 17 mil pressure valve and replace myself as I've managed to realise the original 17mil bolt on the car. I'm excited to fit the new one as I'll get my beloved Honda up and running again. Many thanks Jon. I'll report *** I've replaced the new 17mil bolt
Ok, well fingers crossed that replacing the valve does sort out your problem. However if you performed the test exactly as described at the beginning of this thread then it definitely needed replacing whatever the outcome.
