41 - 59 of 59 Posts
Flip it 180 degrees for the start.
I swapped mine over and can't recall any issues.
There are at least a couple of clips and another couple/three? screws to secure each clip.
Do you have trouble putting your wellies on too? :p Having 2 brackets doubles the confusion eh.
The back of the brackets have square clips that slot into the wing/bracket area.
The secure them with the screws, at different angles.
The bumper rolls up and over them, so align the little bumper clips top/back and you should be sorted.
Play with both until it makes sense.
thanks btw buddy.
this helped me a lot.
Any idea how to remove the little headlight washer caps wit breaking them to bits prior to removing the bumper?
Why'd you want to remove them? - they come off with the bumper, you just have to unclip the main water feed from the bottle. Squeeze the cap and have a bucket ready as the reservoir will empty itself.
Okay so one of the bolts underneath the bumper sheared off earlier while I was undoing it.. Obviously hasn't been off before! Any ideas/tips?
Bob
Mate, you're an absolute legend.
I've managed to take the bumper off, skirts and rear bumper. Cheers dude. ????
Good How To - thanks :)
I have an issue where my bumper isnt clipped in correctly under the drivers headlight (can see the clips on the bumper and arent broken off). Can I remove the fixings on this side and try to get it clipper in rather than remove the whole bumper?
Hello lasses and lads :)
I think I've found right topic to ask my question.
How can I fix this dropbox.com/s/b8c4ha5utv9bhgy/3.jpg?dl=0 ? By this I mean the right side of the front bumper doesn't stay in its "nominal" position.
Here dropbox.com/s/h3gyi0wrugceh7d/1.jpg?dl=0 it seems that this plastic holder is OK although maybe after all this time it's too short or something. It there any way to move this holding element a little bit up or I need a new holding element and in that case I need the name of that element or even better a link to some store where I can buy it. :)
Thank you for your help and as always sorry for my english.
41 - 59 of 59 Posts
