81 - 100 of 152 Posts
Discussion starter · #87 ·
Spend the morning cleaning the motor, installing the K&N 57i as it's suppose to bee installed (sound is not so deep as before :-( ) give all plastic, trim restore and put new clips to fixated the trim
Then I had to polish the left head light and the perspex in the middle, as I had a new right head lamp, after my accident, and the difference was visible, now you cant see the difference so much.
Discussion starter · #88 · (Edited)
What's really interesting is the differences in sound from my K&N 57i airfilter, between the to ways I have had it installed.
The first way the sound was deeper, byt somehow more relaxed, ;-) not sure if I can find a better word to describe it. The air filter was installed inside the old bottom airfilter, and I attached it to the 90 degrees connection.
The new way of installing the air filter is the way K&N recommend, and I have used the 2 rubber hoses that is used to connect to the engine.
Now the sound is more sporty, but also pitched in a way, I'm not sure what I like the most, but the new sound is growing on me :)
Discussion starter · #89 ·
Got the carbon for the gear surroundings fitted, not completely satisfied, as the carbon was delivered without dobbelt sided tape, even though it says so on pimpmycivic homepage.
So I had to find a solution, but the backsides edges of the carbon is raised and I'm having some trouble finding some tape that makes the fit look great.
hi, regarding the gear knob mod:
how did you manged to get the leather boot under the plastic cover?
when I try to put back the cover, it doesn't seem to click back all the way, because of the leather.
did you trim some of the plastic off?
Discussion starter · #94 · (Edited)
Ok so I got around to fit the front grille and the rear center light panel, I had lying around.
Had to do the fog light mood, I had a red LED light I got earlier, to put into the left socket of the reverse light :)
As soon the car is washed, the panel is polished and the weather is good again I go take some pictures
