Hi folks,
I'm one of the guys from the french Honda forum that Clem has talked about in his previous posts. I've carefully read all the posts of this thread, and I'm well aware that a lot of things have already been said. So I'll try to get quickly to the point:
My 1.8 L iVTEC Civic from 2012 shares most of the symptoms that have already been described so far, in other words there's nothing noticeable except an excessively high oil consumption. In particular:
- the problem roughly appeared between 50 000 km (30,000 mi) and 80 000 km (50,000 mi), unfortunately I can't be more precise as I couldn't imagine at that moment that things were about to get worse;
- there is absolutely no leak from the engine, even after removing the metallic "plate" under it (this has been checked two times by two different mechanics;
- there is no weird white/blue smoke or oil smell coming out from the exhaust pipe, even when starting during cold days in winter;
- there is no noticeable influence of driving style, that is to say cruising at 130 km/h (80 mph) on the highway or driving fast on small rally-like roads (changing all gears both frequently and at high revs) over a comparable distance seems to make no difference;
- switching oil viscosity from the recommended 0w20 to 5w30 seems to improve things a little bit (in my case, oil consumption has dropped by roughly 30 % since I've switched to 5w30);
- unfortunately, I haven't already been able to correlate the weather conditions with the oil consumption, mostly because I haven't noticed such an influence and because I don't have enough data yet to provide evidence of this;
- I've noticed a slight decrease in acceleration during the past 2-3 years, but as I've been used to more powerful cars I always found that the Civic is a bit slow so I can't be sure it really does accelerate less.
Now my car has reached 150 000 km (93,000 mi) and I have to put 1 L of 5w30 roughly every 2 000 to 3 000 km (1,240 to 1,865 mi). I plan to continue recording every time I put oil in that damn engine in order to be able to detect an eventual fast increase of the oil consumption. In such a case, I will try to quickly sell my car to a professional.
In the meantime, I plan to send a letter to Honda in order to complain about the excessive oil consumption (even if according to them such a consumption can't be qualified as excessive) and try to insist on the fact that like most of you guys I've bought a Honda believing that the engine would be very reliable, which unfortunately has proven to be wrong so far in my case...
Luckily, I have a friend of mine who can borrow an endoscope at work, so I'll also try to see which type of pistons I have inside my engine. However, I don't think that I will have them replaced if Honda doesn't give me at least part of the money required to perform the operation.
Thanks to all of you, I'll keep you posted as soon as I have more valuable information to share.
Axel
