Rear diff flush (grinding steering)
12K views 7 replies 7 participants last post by  Trevor7979
#1 ·
At the following mileages, we have had these symptoms:
5,000: Odd "WaaaWaaaaWaaaaWaaaa" noise from the rear when at 60 mph +.
10,000: Nasty steering on roundabouts. The steering weighting would increase and then suddenly decrease, resulting in wonky cornering. There was also a slight grinding from the front at low speeds and high steering angles.
15,000: As above, but worse. The steering is now really odd, and the grinding at low speed really loud and quite worrying.
Turns out it's the rear diff (again). Again? I knew the old CRVs had suffered this, but I thought Honda had fixed it. Apparently not.
The reason for the noise is contaminant in the fluid that lubricates the clutch pack. A quick fluid change under warranty transformed the car back to "like new". :)
On certain 07 cars the whole diff needs changing:
View attachment A07-021.PDF
On most cars a fluid flush or two works well ( like on mine):
View attachment A07-024.PDF
An excellent (but US-centric) DIY guide is here:
Black Pearl's 2007 Rear Differential Fluid Change Photo Essay - Honda CR-V Owners Club Forums
According to the Honda tech: "they all do it - it's just a matter of time".
#2 ·
Yup. My old 2007 CR-V needed it done once in the 3 yrs that I had it (must have been lucky) but it does seem to be a known problem.
#4 ·
Hhhhhhhmmmm!
Ponders own car twitching from side to side when medium accelerating now and then.
Erratic torque steer....cv joints.....or grit in the diff ?
#5 · (Edited by Moderator)
Diff
Crv went into the garage on Friday for a leaking rear diff
Got a call from the dealer in the afternoon telling me the car needs a new diff ,might get the car back mid to late November well 6 weeks is not bad considering They wanted me to wait 5 months when my first crv needed a engine :facepalm: .
#7 ·
Just noticed a high pitched whining coming from the diff yesterday cruising on a dual carriageway at 50mph.
Thought it was another car until I realised it was mine!
Had it double flushed under warranty at 30k, looks like it needs doing again at 59k.
Wonder what that will cost me?
#8 ·
Quick update, things appear fine. It looks like it was the road surface on that particular stretch causing the noise!
Not happened since.
