Hi everyone.
I thought I’d bump this thread as I was something I wanted to check.
I’ve only had my ‘09 FN2 Type R a couple of years and I’ve had a problem with my head unit lcd since. I was going to replace it this summer as I’ll be using the car more. There was something I wanted to run past you before I do.
The light flickers on and off with vibrations. Sometimes it may stay on, other time bumps will cause it to flicker or knock it off completely for a short while. I always assumed it was the same issue described here. However for the first time this weekend natural light caught the LCD in such a way that I could see all the characters actually all the characters are fine, it’s actually just the backlight that’s flickering off and on.
Now if it makes a difference, ever since I’ve owned the car the rear illumination on the stereo that should come on when I turn my lights on doesn’t work. It maybe worked 2 or 3 times but rarely comes on. Im sure I read somewhere that the 2 can be related. However the rear illumination doesn’t flicker off and on like the LCD. I’m not bothered about fixing that to be honest as I only ever use my aux port.
Also I hit a bump with a bit of jolt a while back and the LCD actually behaved for a good couple of hundred miles.
So with this in mind, is this one of the symptoms of the poor soldering or does it need replacing?
Is it even a problem with the LCD or is it a wire that’s broken?
Is it actually tied in to the stereo illumination in any way?
Finally if I need a new one, does anyone happen to have the part number for the Red version that’s on the type r?
Edit - I’ve got the part number. If it helps anyone it’s HR0367001
